Old 05-14-2014, 01:57 PM   #1
Silverkarn
Drives: 2008 Toyota Yaris 2D
Anyone replace their oil drain plug with one of these?
http://www.qwikvalve.com/
I just read about this on some blog, anyone use one? Any problems? I think this would be great if you change your own oil. And if you decide you don't want to change your own oil once in a while just bring the plastic bit and the hose with you to the oil change place.
So. How long have you had it on your car? And have you had any problems with it?
Silverkarn is offline   Reply With Quote
Old 05-14-2014, 02:07 PM   #2
Yes. I have Fumoto quick valves on all of my vehicles. The oldest one I have had on for over 5 years without issue. If you are lowered, you need to be careful as the valve hangs lower than the drain bolt head would have.
Old 05-14-2014, 02:55 PM   #3
schume
Drives: 2010 Yaris LB
I put these on every car I own at my first oil change. Sometimes the lever might not be oriented exactly the way you want, but I've never had any leaks or issues. Well built units.
schume is offline   Reply With Quote
Old 05-14-2014, 04:02 PM   #4
Silverkarn
Car is stock height. They have one that is made for cars that have been lowered. I'll probably end up getting that one as i do go over speed bumps quite often.
Old 05-14-2014, 04:33 PM   #5
MyzticZ3r0
I got one a couple years ago and I had the unfortunately luck of the valve stripping my oil pan and leaked oil. I'm a small percentage of this happening, but thought I'd let you know it does.
MyzticZ3r0 is offline   Reply With Quote
Old 05-14-2014, 05:00 PM   #6
marauder
marauder's Avatar
Drives: '08 Yaris
Yep, tried this on my RX-8 and had the same problem. The adapter needed to fit the valve on my vehicle caused the final location of the drain valve tab to be the lowest point of the car and facing the rear of the vehicle. Any minor hit would open the valve. I was told to add washers to adjust the final position, the problem was I needed to clear almost 90 degrees of rotation.
They do recommend you install the safety spring just in case, which I would highly recommend because it also keeps some punk from draining your oil easily should they be crawling around underneath your car for whatever reason.
The valve adapter and safety spring I bought for my RX-8 is still new in the box. I'd give mine to you but it looks like the drain plug size is not the same.
marauder is offline   Reply With Quote
Old 05-14-2014, 11:13 PM   #7
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
I just replaced with one of these:
Monitoring engine wear without paying for UOA.
jack black is offline   Reply With Quote
Old 05-15-2014, 03:04 AM   #8
Silverkarn
What is that?
Old 05-15-2014, 09:14 AM   #9
marauder
marauder's Avatar
Drives: '08 Yaris
Looks like a magnetic drain plug to me.
Old 05-15-2014, 10:18 AM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
It's a goldplug. http://www.goldplug.com/
i have one of those in mine. There are fine metal particles on the plug each time i change oil...
Old 05-15-2014, 01:32 PM   #11
nortonfb
Drives: 2007
I have been using those for a long time. Some cars seem to always have a
little bits attracted.
Cheap insurance, if you change your oil.
Steve
nortonfb is offline   Reply With Quote
Old 05-15-2014, 06:52 PM   #12
monchito18
monchito18's Avatar
Drives: Yaris sedan
Send a message via MSN to monchito18
I can't have that here, car scrapes everywhere :(
monchito18 is offline   Reply With Quote
Old 05-16-2014, 01:15 AM   #13
UberSilver
UberSilver's Avatar
Got them on my Bike and Land Cruiser, but I don't like the location for the yaris, so I past. Plus I change my oil once per year, so it's not all that needed in my case.
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 02:43 PM
oil drain plug- gasket eddy DIY / Maintenance / Service 38 10-17-2009 12:00 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 02:55 PM
