Old 05-17-2014, 05:16 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by j-san View Post
Thanks for the input, CTScott. Unfortunately, MicroImage has neither the 19mm or 23mm sway bar in stock at this time. I found a TRD sway bar on TRDSparks. Seems the reviews on this unit are quite favorable. Apparently any sway bar in the rear makes a significant improvement over stock for handling.
I highly recommend the TRD sway bar. It was one of my first mods. The design is impeccable, as it fits snugly up inside the concave indentation of the rear axle assembly. It also installs in just a few minutes...
I live in a rural area where I need all the ground clearance I can get, and the TRD rear sway bar doesn't hang down to compromise it like the other bars do.
I also spaced out my front wheels 5mm and the rears 10mm for a slightly wider stance, and installed wider 15x7 alloy wheels with wider 195/60 Bridgestone Potenza tires. This particular wheel/tire combination is the same as the stock wheel diameter, and so retains the factory accuracy of the speedometer and odometer.
It handles like a slot car.
Greg
Old 05-17-2014, 05:23 PM   #2
Rigaud
Drives: 2009 Yaris
Greg
Same reason I picked the TRD. No one had them in stock, you can find them on ebay for $165 (+-) plus shipping, got mine including shipping $200.00.
Old 05-17-2014, 05:30 PM   #3
tooter
play every day
tooter's Avatar
Yup... I got mine off of ebay , too.
Greg
Old 05-18-2014, 11:08 AM   #4
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
wow this is crazy...i so wish i lived with no rust lol cos my sway bar to install required heat on lower shock ...must be nice working on cars that are always clean .
Old 05-18-2014, 06:37 PM   #5
Rigaud
Drives: 2009 Yaris
That picture is from Tooters car not mine. ;) I live in the land of road salt, lot's of it!!! I got lucky purchasing a 2009 this January that was mint. It won't see winter roads again. :D
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
Stiffer suspension - same ride height? fuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-13-2009 07:53 PM
stock ride height or spring sag? mikeukrainetz General Yaris / Vitz Discussion 5 12-21-2006 01:00 PM
17" or 18" with stock s sedan suspension? manborn Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 10-13-2006 09:43 PM
Air Ride suspension for Yaris Sedan fouad84 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-13-2006 07:39 AM
