Old 05-30-2014, 11:44 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
you only need to initiate the procedure if you want to use the remote starter. Else, it won't work. the reason for that on a manual car is to make sure you leave the car on neutral, so you won't kill a little kid when you hit the remote starter.
Old 05-30-2014, 12:15 PM   #2
GrayYaris
Drives: Gray
I remember being in a 5 speed Saturn once and it would only shut off when the driver's door was opened and closed. I'm glad to hear it will turn off normally otherwise.
Any clue about not connecting the other functionality of the module?
GrayYaris is offline   Reply With Quote
