![]() Drives: Toyota Yaris TR 08 Join Date: Jun 2014
Hi Everyone,
I bought a Yaris 1.3 '08 model (imported from uk to pak) and have been driving it around for 5 months. The car was in mint condition, it was perfect as long as winters were there. Didn't notice any problems until summers came and i had to use the AC. what happens is that as soon as i turn the AC ON, for a while it throws out chilled air bt as i drive on, the air gets warmer and it gets pretty warm. when i turn off the button and back on again, chilled air comes back bt after 5 mins or so it recedes again. I have had it checked from several local mechanics and this is what they did. 1. I had a freon re-fill as the mechanic proposed, the problem persisted and i had a 2nd re-fill which didnt solve the problem either 2. next time, the mechanic said there was a leakage in the hose so he replaced the entire pipe, which didn't solve the problem either 3. after changing, i had the drainage pipe cleaned several times but the problem persisted 4. Finally, it turned out the sea-air during import of car had corroded the filter and compressor, so I had it all entirely replaced. For about 3 weeks it seemed to have solved the problem, But now it's back on again. The AC throws cold air for about 10 mins but as i drive further, the air gets normal and then warmer. Also, the AC does not perform v good when outside temp is v hot (above a 100 degrees). NOTE: The car is imported so not covered under any warranty/insurance claims. I have already spent a lot of $$ on it n the problem has persisted, so i want to have suggestions on what i should look for now. Much thankful for ur support!! |
does the radiator fan turn on when the AC is on?
If the fan stops running, it is likely that the system is either under or over filled. If the pressure is not within a specific window the AC ECU will shut the system down to prevent damage.
FAN working ok
The fan keeps running, i can feel the air coming out its just ot cold ac air after a while its simple fan air. However, restart the AC button, n the fan throws cold air again for abt 5 mins.
![]() ![]() ![]() Drives: 2007 Yaris Sedan Join Date: Apr 2009
The fan you are talking about.
Is it the one that is on the Radiator or the one that distributes the air inside the car? The fan on the radiator is the one you have to look at. |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Scott is correct. If you can do the cycle endlessly, it means there is no freon loss ergo no leak.
my guesses are: 1) overfilled freon pressure 2) faulty condenser fan (engine bay) causing overpressure in the system HTH |
| Tags |
| ac problem, compressor, freon, toyota yaris 2008, yaris |
| Help: dealer might not be able to fix window problem (2012 Yaris) | matti | Third Gen Yaris General Discussion | 5 | 01-31-2013 10:37 PM |
| **SAFETY RECALL!! 06-07 YARIS HB & SEDANS** | slvryaris | DIY / Maintenance / Service | 83 | 09-30-2012 12:25 PM |
| Yaris Cold start problem | vinny121 | DIY / Maintenance / Service | 12 | 05-09-2011 10:36 AM |
| Electrical System problem 2006 Yaris | Ivriniel | DIY / Maintenance / Service | 12 | 05-10-2010 02:55 AM |
