Old 06-18-2014, 11:18 PM   #1
Viperoni
Drives: 2005 Toyota Echo
Big partout of Echo stuff
Alas the time has come - I've moved on from my Echo, including the chance to make it a project car. My hatch has gone to a good home though.
So here's the big partout - pics coming soon:
K&N Typhoon short ram intake, off of a coupe, will NOT fit a hatchback.
Has a MAF sensor in it (no idea if it's good).
Price: $50 NOW $35 NOW $30
BNIB Replacement friction surface for a Spec flywheel
Was told my old parts car had a Spec flywheel, turns out it was only a Spec clutch. The flywheel was actually an Unorthodox Racing unit.
Price: $50 (paid almost $100 for this) NOW $40
Unorthodox Racing (UR) lightweight aluminum flywheel
Minor nicks in the center area where one of the clutch's spring tabs broke off and rattled around, all surface imperfections, the friction surface is still fine.
Price: $50 SOLD
Pic 1
Pic 2
Pic 3
A PAIR of BNIB Timken rear wheel bearings with ABS sensors
The BEST wheel bearings you can get for an Echo. Will also work on non-ABS Echo's.
Price: $180 (Paid over $125 a piece for these from rockauto.com, plus shipping!) NOW $140 SOLD
Pic 1
Pic 2
Non-stock front sway bar off of a coupe
Comes with the poly bushings pictured
Price: $40 NOW $30
Sustec rear underbody frame brace
Great shape, very little use, ncie and light
Price: $50 SOLD
Pic 1
Pic 2
GT Spec front underbody frame brace
Obviously a little rough from the previous owners use, still straight as a ruler
Price: $50 SOLD
Pic 1
Pic 2
Pic 3
Pic 4
Front control arms with new Moog problem solver ball joints, new Energy suspension front bushings and new Whiteline CASTER CORRECTING rear bushings
The best thing you can do to improve suspension & steering geometry and improve steering response
Price: $200 NOW $170
Hot Bits Adjustable Coilovers
Fronts have pillowball camber adjustable upper mounts
All need a rebuild - the quote from Peter at Hot Bits Canada in Brampton, Ontario was $400 to $700, depending on if new rods are needed. He is a 10 minute drive away from me and I can help facilitate the rebuild if you'd like.
This is the BEST upgrade you can make to your Echo's suspension, and with Peter matching the struts to the springs included or the ones you want to use, will be better handing than any other coilovers out there for around $1000 all in!
Price: $500 NOW $450 NOW $400
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 06-19-2014, 07:47 AM   #2
KTS
KTS's Avatar
Drives: Vitz RS
I am interested in the Unorthodox Flywheel.
I have a few questions I hope can be answered before we can proceed.
1. Will it fit a 2007 Vitz RS?
2. Can you direct me to a link where a replacement clutch lining/surface can be purchased.
3. Cost to ship to 33172?
Once the shipping and the replacement surface can be purchased at a reasonable price I will buy the flywheel.
thanks
KTS is offline   Reply With Quote
Old 06-19-2014, 09:04 AM   #3
Viperoni
thanks
1. Yes, flywheels are the same between the Echo and 1.5L powered Yaris'
2. I'll check a couple resellers to see if they can get a replacement friction surface
3. I'll PM you seperately
Old 06-19-2014, 11:41 AM   #4
KTS
KTS's Avatar
Drives: Vitz RS
Ok thanks alot.
Old 06-28-2014, 04:52 PM   #5
KTS
KTS's Avatar
Drives: Vitz RS
is the flywheel still available??
Old 07-23-2014, 09:07 AM   #6
Viperoni
^ Bump ^
Old 07-28-2014, 01:57 AM   #7
DivineHelios
Drives: Toyota Echo RS
Hi, I am new to this forum.. Just bought 2004 Toyota Echo RS few months ago as my first car. I have a question, will your underbracings fit my Echo? I am interested with your Sustec Rear Underbracing and GT Spec Front underbracing, thanks for your time =D
DivineHelios is offline   Reply With Quote
Old 07-30-2014, 08:34 PM   #8
Viperoni
Just sent you a PM DivineHelios, the braces will definitely fit your Echo.
Old 08-23-2014, 12:10 AM   #9
Viperoni
Bump for price drops
Old 09-15-2014, 10:03 AM   #10
Viperoni
Updated sold items and lowered prices!
New Budget Big Brake Kit on the Horizon! wildmongoose26 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 12-20-2013 04:20 PM
Save thousands and BIG MPG almost PRIUS jay cobbs New YARIS Purchase Forum 6 08-28-2012 09:38 PM
Yaris and Echo short shifters sale, $30 off! TWM Performance TWM Performance 8 11-17-2008 03:23 PM
Razo Stuff? mastaofdisasta Cosmetic Modifications (Exterior/Interior) 6 11-06-2008 01:10 AM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 03:13 PM
