Old 06-19-2014, 08:56 PM   #1
ReedH
Drives: 2013 Toyota Yaris Hybrid
Here's a picture of the connector and the wire that you need to add. This wire tells the system that the car is in reverse.
As a test, you can try connecting this to the cigarette lighter or another +12V source in the car. You want this pin to be +12V when the car is in reverse(connect the other end of the wire to a +12V reverse signal). Some have found the reverse wire in bundle in the driver kick panel. You can do that or you can wire it to the reverse/tail light harness.
ReedH is offline   Reply With Quote
Your opinion on 2nd gen vs 3rd gen resale value chocolab General Yaris / Vitz Discussion 5 12-03-2013 11:05 PM
Noise from rear of Yaris APS67 DIY / Maintenance / Service 5 09-25-2011 06:51 AM
