Old 04-11-2007, 01:39 PM   #1
hmmm, now you have me worried, but then again, Black Yaris said that the Prius comes with that weight and viscosity oil.
Old 04-11-2007, 07:21 PM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
Never confuse the engine in the Yaris with the one in the Prius. Even though they have the same designation (1NZ-FE) there are 2 major differences between them:
1) The Prius' ECU runs the engine in an Atkins cycle which involves a longer spark at a lower temperature (for ionization) and requires less fuel as it burns more thoroughly but at a lower RPM/torque level. The Yaris' ECU runs the engine in a typical Otto configuration which involves a short and hot spark at the top of the compression stroke. This means the Yaris' engine runs at higher RPM and hotter.
2) The Prius' engine is almost never in a direct wheel feed scenario. The engine feeds to the HSD and the battery (which in turn runs the electric motor), and the HSD plays a hardcore game of matching inputs from both the engine and motor to produce torque in the CVT. The CVT in turn plays a hardcore game of balancing torque input and output to produce movement. These systems are a far cry from the Yaris' direct feed to either a transmission (MT) or torque converter (AT) which immediately convert torque to wheel drive.
The point of all of this is that the Prius' engine only receives about 1/3 the beating that the Yaris' does. As such you can get away with a lighter oil in the Prius than you can in the Yaris.
As with most other things sticking to the manufacturer's recommendations is best, and Toyota says 5W-30 for the Yaris.
- Brian
Share the Road
Old 04-12-2007, 12:34 AM   #3
what about the TSB's that were mentioned earlier?
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
Oil Question 91drggndime DIY / Maintenance / Service 7 03-23-2007 07:52 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 09:44 PM
