Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
Thanks! For once, somebody who doesn't berate me for not going slammed! It's like peer pressure, I tell you.
And you're right about the adjustability. It's my nature to tweak things, so this worked out well. I'd like to keep adjustments to a minimum though, because alignments aren't cheap. I take it you're all too familiar with winters. Are you from the GTA? Sent from my XT1032 using Tapatalk |
#2 | |
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
#3 | |
Minimalist
And after reading Tamago's writeup http://www.yarisworld.com/forums/showthread.php?t=14026 I'd be interested in adding a touch more toe-in and negative camber over stock, if they're not at that spot already. And if I feel a little adventurous, I'll try that flat washer shimming on the bolts between rear hubs and axles to get my rear toe and camber set. Those, after all, can be reset to "defaults" without needing the shop's rack, right? Sure, it's only 1 1/2" (38 mm) of lowering, but I only intend to make up to 1/2" (13 mm) of adjustment up or down anyway. Assuming this logic works, if the alignment is set to my "midway" height -- the parameters of which you can bet will be recorded for future reference -- there should be no real need for realignment afterwards, as long as I stay within that +/- 1/2" of adjustment. Not like I'll miss anything far below or above that. And the place I'm having it done at will let me dictate some last minute adjustments of my own while the thing's up on their lift. $102 gets all that done, and for quite some time afterwards I doubt I'll need it redone. Last edited by sheekeebut; 06-26-2014 at 03:19 AM. Reason: don't know how exactly to describe the steering feel |
Minimalist
And thanks to microimage resources
http://microimageonline.com/forums/s...TECH-TSB-FILES More specifically http://www.microimageonline.com/down...Suspension.pdf starting at page SP-59 (pdf file page 61) I can visualise the axles' mounting plates and bolt patterns without even having to jack my car up. |
#5 | |
![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Yaris 2007 Sedan in Canada | David81 | New YARIS Purchase Forum | 16 | 09-09-2007 02:09 PM |
| My Review of My Yaris Sedan 2007 | David81 | New YARIS Purchase Forum | 6 | 09-10-2006 12:48 AM |
