Henry Mak
Drives: 2009 Toyota Yaris 2dr-hatchbk Join Date: Aug 2012
Coilovers vs TRD Suspension?
What is the main difference between coilovers vs trd lowering springs + trd shocks (http://www.toyotaracing.com/trd/part...tegories=all)?
Expecting more of a scientific answer as to how it works. Thanks!! |
Coilovers are made with full adjustability. Either height, bound and rebound or all of the above.
TRD springs + shocks are well just that... |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
More then just that if you purchase proper springs and struts also for those that know what their doing. Same for coil overs you need to know what your doing or get help.
Adjustable ride height and spring rate vs. Static ride height and spring rate.
That's pretty much what it boils down to. No need to get scientific about it.
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
+1, coil overs give you adjust-ability of everything. ride height, shock stiffness, spring length / stiffness, it all boils down to what you want and how you want it. If your likings change, so can the coil overs. Lowering springs can be a let down if you don't already know exactly how you want it :x
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
You can also continue to swap in shorter and stiffer springs if you want to keep going lower, once you pickup some tein springs thats as short as you will go on springs/shocks combo and it is less than 2" of drop. Stiffer allows you to control spring rate and you can go into 1000 lb springs or higher if you so desire, springs probably dont go higher than 5-6k
![]() ![]() Drives: 2010 5-door hatchback Join Date: Mar 2014
Are there coil-over sets that match the stock ride height? Every coil-over kit I see for the Yaris is made for lowering.
#8 | |
The primary purpose of coilover is so a person can set height to whatever tickles their fancy. I do believe that with the spring perch at full up, a coilover matches, or comes close to, stock height.
Yup, stiffer spring rate at stock height. I'm not a fan of lowering my car, but I would like to try and improve the handling at the stock height. My car is probably due for new shocks and struts so I am just curious about the differences.
#10 | |
ps ...TRD drop is .5 up front and 1.5 rear ..it levels the car nice |
Form>Function
you can adjust your coilovers to be pretty high but idk about all the way up to stock height
Only Happy When it Rains
Most coil's won't go to stock height, but some will only lower it an inch or two. The Yaris sits so high an inch or two is not that big a deal unless you need to go off road a lot.
The real difference is in the ride. Some shocks like the Tokico Reds are adjustable, and can ride really softly, and so can some coilovers. Others are rather harsh.
Colin Chapman disciple |
| Help with sizes for wheels running TRD suspension. | Captain Slow | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 49 | 12-07-2011 06:48 PM |
| Sedan owners with full suspension mods? specifically all TRD | AdeJong 03 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 05-15-2010 12:13 PM |
| trd suspension | elijahsami | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 11-09-2009 05:15 AM |
| For Sale: TRD sportivo suspension | Hocc | Australia | 8 | 10-16-2009 07:24 AM |
| 09 LB - Scion rims + TRD Suspension | regal | Photo-Video-Media Gallery | 8 | 04-17-2009 11:05 PM |
