#1 | |
Winterizing
Drives: 2010 Toyota Yaris Hatchback Join Date: Oct 2011
I looked at the “Scheduled Maintenance Guide.” It never says when to change but it says when to check it. It says to check it pretty often. I have 100K miles on my Yaris now. I bought it with 50K and don't know if the fluid was ever changed. I used the dipstick and saw the level was good. The color was purple, but a little dark. No metallic flakes or anything. I have no problems shifting (automatic). Is it bad for the fluid to be a little dark? Is there a good reason for me to change the fluid or even clean the filter and change the gasket as this website below instructs? (I know how much to use and to only use Toyota fluid.) http://microimageonline.com/forums/s...ice-inspection
33.7 mpg in PA
#2 | |
I check my level once a year and inspect the transmission for leaks while up on ramps for oil changes.
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
