Ya full synthetic 5w30 or in ur case 5w40 ...Toyota has either regular or for extra syn oil but won't have 5w40 ...u see 5 means start up are both same but by going to 40 the oil will stay thicker at high temp so won't fin out think it would be ideal for ur application ..hot weather and stop and go traffic .
#2 | |
Fugitive
Drives: 2007 Yaris 4 Door Hatch Join Date: Jul 2014
![]() Thxx a lot !!! |
You wont have a problem with any synthetic 10w-30 product, your owners manual will probably explain in more specific detail.
Have Yaris will travel.. |
Fugitive
oil grade should be written on the oil cap on the engine. Unless it has been changed for an aftermarket one..
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Brake/Transmission Fluid questions | Rutherford | DIY / Maintenance / Service | 1 | 02-06-2014 05:22 PM |
| So when DOES the transmission fluid need to be changed | dutchy999 | DIY / Maintenance / Service | 12 | 09-06-2011 05:18 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
