With those DTCs, I suspect that you have a second bad OC ECU. It also could be that the SRS ECU side of the communications was damaged by the hot unplugging.
My OC ECU bypass module unfortunately won't help if the OC ECU or SRS ECU are bad. I believe I have a spare (and tested) OC ECU. I may also have a spare of the correct SRS ECU.
| Tags |
| passenger airbag, passenger seat, seatbelt light, srs light |
| SRS warning light - any guesses? | Goose | DIY / Maintenance / Service | 15 | 03-24-2014 01:57 AM |
| Battery warning light stays on... | routerunner | DIY / Maintenance / Service | 2 | 02-23-2013 09:53 AM |
| SRS Warning light blinking | Nel007 | DIY / Maintenance / Service | 1 | 10-02-2012 08:22 PM |
| SRS warning light and dealership fun :) | wsladaritz | General Yaris / Vitz Discussion | 16 | 09-18-2010 04:37 PM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 02:04 AM |
