Old 07-17-2014, 11:05 AM   #20
Jason@SportsCar
Originally Posted by CrankyOldMan View Post
Differentials for C56 and C59: may be the same as the xD. RagnaCaT on microimage is in the process of swapping an LSD into an xD gearbox to put on his Yaris and discovered that the xD has a different differential, despite having the "same" C50 gearbox.
Does the xD have a different final drive and output shaft as well, or just the diff? *I know it is a different ratio, but is it physically different to the point it wont swap...
changing gear from robotic to automatic mariann DIY / Maintenance / Service 13 12-09-2011 06:43 PM
Gear Ratios J_T Performance Modifications 1 06-16-2011 12:31 AM
Changing Gear Oil Of the C160 Parmas DIY / Maintenance / Service 12 01-20-2011 02:44 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Gear Ratios? aephilli DIY / Maintenance / Service 3 04-12-2007 05:38 PM
