Old 09-01-2014, 05:51 PM   #1
Originally Posted by sadarahu View Post
False conclusion. After 5 days the charging Led is ON again !
but this time horn is still working
oooh my,....
Is thee any way to check if it is an alternator which is bad or something else ?
of course without installing a new one
Checking the voltage is meaningless in this case. Simply when it is not charging I get 0V and when he light goes off a get 13+V
I wonder how this problem could be possibly related to the battery going bad ? If this is rally a possibility then I can reconnect my boat battery (almost new) and see what happens, but
I'd like to know if it is worth the try ? Not sure if this is related but the charig problem returned right after I washed the car.
still do no know if connecting computer tester to the outlet on the left under the dashboard will show anything or give any clue ?
Art
Where are you taking measurements? You should never see zero volts.
charging issues help please shockedmustang DIY / Maintenance / Service 9 02-24-2014 01:28 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
Good source for the tiny, half-height OEM fuses? schleppy In Car Entertainment + Electronics (audio / video / alarm) 6 05-19-2009 04:55 PM
Replacement Fuses Meteorite_Marty DIY / Maintenance / Service 6 12-30-2008 04:15 AM
