Old 07-19-2014, 08:00 PM   #1
gone_in_sixty_seconds
gone_in_sixty_seconds's Avatar
Drives: White 2009 4door sedan Yaris
msg in regards to miss log
I did an oil change within a couple weeks prior to the error and the oil I used was the 5W-30 Synthetic Motor Oil which should of giving me 15,000 miles after the oil change. So if scanner misread the ecu, do you think i have an oil leak problem? Yes The Abs indicator has not come up.
gone_in_sixty_seconds is offline   Reply With Quote
Old 07-19-2014, 08:22 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
The indicator is programmed for 5000 miles and will come up once reached.
Toyota recommends oil changes every 5000miles wether you are using synthetic oil or not.
Tags
c1201
