Old 07-29-2014, 01:42 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Just over 2 lbs.
Old 07-29-2014, 01:45 PM   #2
Originally Posted by CrankyOldMan View Post
Just over 2 lbs.
Ah, not as heavy as I thought. I suspect that its purpose is to dampen vibration through the cable to the shifter, and possibly to assist with shifting as the momentum of it would help with fully engaging a position. The shape is probably just based on what's around it once the tranny is mounted in the engine bay.
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
