Old 08-01-2014, 07:57 AM   #1
Rigaud
Drives: 2009 Yaris
I did not disconnect the battery, left it live. Swapped chips and removed the epoxy to dial the idle but only while it wasn't running. The P0505 is due to high idle and the oscillation the ECU searching and needs to learn. I had the oscillation too at first, it went away after a day or two. I had the P0505 popping up every day for two weeks but it took longer every time for it to show up. Eventually all has settled itself and works great. Best direct upgrade I did so far. My installation went fairly well because I did some reading on hear first before doing the job and not after the fact. ;)
Give it some time for your ECU to relearn with the bigger TB.
1zzfe throttle body lilman717 Performance Modifications 22 02-12-2009 07:08 PM
intake and throttle body Q thebarber Performance Modifications 3 08-20-2007 07:02 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
toyotafest 2007 esquiva Photo-Video-Media Gallery 36 05-15-2007 12:03 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
