That looks quite normal for 02 sensor output.
Since you can smell it in the cabin of the vehicle, I would check for exhaust leaks, particularly where the exhaust manifold connects to the exhaust pipe.
#2 | |
![]() Drives: Toyota Premio NZT240 Join Date: Jul 2014
Thanks. |
Have you cleaned the MAF sensor? Also, if the injectors are plugged they could cause the fuel to not properly atomize and therefore not fully burn.
I changed out the MAF a month back (The old one died), I too am suspecting the injectors, but in the past when the injectors needed replacing there would be issues with acceleration or the throttle would be laggy none of which are present right now. The car runs fine except for the strong exhaust smell. Do you think I should swap out the injectors?
#5 | |
| Spark plug torque | Geoff Peace | DIY / Maintenance / Service | 11 | 05-05-2021 02:48 PM |
| Torque wrench - looking for a particular type | Yarflana | DIY / Maintenance / Service | 10 | 04-05-2013 12:09 AM |
| Effect of DC headers on torque curve? | Captain Slow | Performance Modifications | 23 | 02-10-2013 11:52 AM |
| Torque wrench on lugs is critical on the Yaris | A-Dingo-Ate-My-Baby | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 12-13-2011 06:33 AM |
