![]() Drives: Toyota yaris D4D Join Date: Feb 2013
Hello CTScott, our operation is off does nothing, in on doing intermittent wipe and spray the water makes continuous, also has another position to just spray the water, so my question is the intermittent wipe.
Ours is this command: ![]() And I'm going to buy is this: I want auto function because I want to put a rain sensor.
Sorry for the translation since I do through a translator, (spanish --> english). |
#2 | |
#3 | |
I put a video I made this afternoon with the operation. https://www.youtube.com/watch?v=uN5kz8EkJag
#4 | |
Interesting. Check the wiring going into the wiper switch to see if someone installed a wiper delay module. In the ON mode they normally run continuously, like yours does in the spray mode.
The truth is that if someone has installed a module or something has been in the actual assembly of toyota since we bought the car new, the truth that I dread plug and non-plug and play like your tutorials.
I just realized you are in Spain. For some crazy reason I had assumed you were in Puerto Rico (with a US spec Yaris). Now, I am thinking that the European Yaris has something different about the internals of the wiper switch that causes the delay in ON mode.
#7 | |
What most interests me is that it is compatible with the car and can put without problems that do not match the wires to the main functions.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| variable intermittent wipers | thebarber | Cosmetic Modifications (Exterior/Interior) | 27 | 10-18-2022 04:26 PM |
| DIY Variable Speed wiper stalk install | DanQ | DIY / Maintenance / Service | 27 | 08-03-2017 08:22 PM |
| Florida Yaris Roll Call: Part 3- Post Hacking! | Sabretooth | Southeast | 81 | 05-22-2009 11:39 AM |
| Making Intermittent Rear Wipers | ttufrosty | Cosmetic Modifications (Exterior/Interior) | 1 | 08-12-2007 11:57 PM |
