Old 08-06-2014, 02:29 PM   #1
Rakin
Drives: Toyota Premio NZT240
Have you cleaned the MAF sensor? Also, if the injectors are plugged they could cause the fuel to not properly atomize and therefore not fully burn.
I changed out the MAF a month back (The old one died), I too am suspecting the injectors, but in the past when the injectors needed replacing there would be issues with acceleration or the throttle would be laggy none of which are present right now. The car runs fine except for the strong exhaust smell. Do you think I should swap out the injectors?
Rakin is offline   Reply With Quote
Old 08-06-2014, 02:39 PM   #2
I would say only to do so if you have an extra set on hand. Also, verify that the new MAF is the correct part number for your car. I have seen autoparts places over here sell people Tundra ones, which look identical, but have a different part number.
Spark plug torque Geoff Peace DIY / Maintenance / Service 11 05-05-2021 02:48 PM
Torque wrench - looking for a particular type Yarflana DIY / Maintenance / Service 10 04-05-2013 12:09 AM
Effect of DC headers on torque curve? Captain Slow Performance Modifications 23 02-10-2013 11:52 AM
Torque wrench on lugs is critical on the Yaris A-Dingo-Ate-My-Baby Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-13-2011 06:33 AM
