Old 08-06-2014, 06:31 PM   #1
Originally Posted by duende_80 View Post
The question is that mine does not have the continuous function unless you pull the water sprayer.
I put a video I made this afternoon with the operation.
https://www.youtube.com/watch?v=uN5kz8EkJag
Interesting. Check the wiring going into the wiper switch to see if someone installed a wiper delay module. In the ON mode they normally run continuously, like yours does in the spray mode.
Old 08-06-2014, 06:38 PM   #2
duende_80
duende_80's Avatar
Drives: Toyota yaris D4D
The truth is that if someone has installed a module or something has been in the actual assembly of toyota since we bought the car new, the truth that I dread plug and non-plug and play like your tutorials.
Sorry for the translation since I do through a translator, (spanish --> english).
duende_80 is offline   Reply With Quote
Old 08-06-2014, 06:47 PM   #3
I just realized you are in Spain. For some crazy reason I had assumed you were in Puerto Rico (with a US spec Yaris). Now, I am thinking that the European Yaris has something different about the internals of the wiper switch that causes the delay in ON mode.
Old 08-06-2014, 06:54 PM   #4
duende_80
duende_80's Avatar
If could be that the European version instead of intermittent and continuous scan so serious safer backwards that you would lose, continuous sweep.
What most interests me is that it is compatible with the car and can put without problems that do not match the wires to the main functions.
Old 08-06-2014, 07:03 PM   #5
I just looked at the European wiring diagrams and there are two versions (with intermittent and without intermittent). The intermittent function is built into the wiper motor assembly, not into the switch.
Old 08-07-2014, 02:37 PM   #6
duende_80
duende_80's Avatar
CTScott Hi, I could not answer before as I have been out all day and gone to buy the command of clean, but the joy did not last long.
In my car the rear wiper works perfectly, the two positions, intermittent and continuous, but have been to test the front and the front turn signal does not work and if I give the water sprayer expels water only and do not move the clean, I guess it has something to do with the four wires to a connector that brings greater.
Old 08-07-2014, 02:43 PM   #7
Did you make any wiring modifications on your car? The turn signals and wipers are not wired into the same connector.
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
