![]() Drives: Toyota yaris D4D Join Date: Feb 2013
The truth is that if someone has installed a module or something has been in the actual assembly of toyota since we bought the car new, the truth that I dread plug and non-plug and play like your tutorials.
Sorry for the translation since I do through a translator, (spanish --> english). |
I just realized you are in Spain. For some crazy reason I had assumed you were in Puerto Rico (with a US spec Yaris). Now, I am thinking that the European Yaris has something different about the internals of the wiper switch that causes the delay in ON mode.
#3 | |
What most interests me is that it is compatible with the car and can put without problems that do not match the wires to the main functions.
#4 | |
#5 | |
CTScott Hi, I could not answer before as I have been out all day and gone to buy the command of clean, but the joy did not last long. In my car the rear wiper works perfectly, the two positions, intermittent and continuous, but have been to test the front and the front turn signal does not work and if I give the water sprayer expels water only and do not move the clean, I guess it has something to do with the four wires to a connector that brings greater.
#6 | |
Sorry, I wanted to say that intermittent function not working front or the clean sweep clean by spraying with water.
| variable intermittent wipers | thebarber | Cosmetic Modifications (Exterior/Interior) | 27 | 10-18-2022 03:26 PM |
| DIY Variable Speed wiper stalk install | DanQ | DIY / Maintenance / Service | 27 | 08-03-2017 07:22 PM |
| Florida Yaris Roll Call: Part 3- Post Hacking! | Sabretooth | Southeast | 81 | 05-22-2009 10:39 AM |
| Making Intermittent Rear Wipers | ttufrosty | Cosmetic Modifications (Exterior/Interior) | 1 | 08-12-2007 10:57 PM |
