Old 08-07-2014, 02:43 PM   #1
Originally Posted by duende_80 View Post
CTScott Hi, I could not answer before as I have been out all day and gone to buy the command of clean, but the joy did not last long.
In my car the rear wiper works perfectly, the two positions, intermittent and continuous, but have been to test the front and the front turn signal does not work and if I give the water sprayer expels water only and do not move the clean, I guess it has something to do with the four wires to a connector that brings greater.
Did you make any wiring modifications on your car? The turn signals and wipers are not wired into the same connector.
Old 08-07-2014, 04:01 PM   #2
duende_80
duende_80's Avatar
Drives: Toyota yaris D4D
Sorry, I wanted to say that intermittent function not working front or the clean sweep clean by spraying with water.
Sorry for the translation since I do through a translator, (spanish --> english).
duende_80 is offline   Reply With Quote
Old 08-07-2014, 04:11 PM   #3
OK. So, the front intermittent and spray do not work, but the front constant slow and fast do work?
Old 08-07-2014, 06:52 PM   #4
duende_80
duende_80's Avatar
If the rest works, it happens exactly the same as toy toronto in this post: http://www.yarisworld.com/forums/sho...6&postcount=60
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
