#1 | |
Actually as long as the highest gear ratio (ie 4th in a four speed, 6th in a six speed) are the same so will the mileage be. And because you are winding through the gears (and burning gas as you do so) the more speeds the transmission has the worse the mpg. Thus the most efficient transmission is a three speed NOT a six speed. Get it?
#2 | |
If one wound through the gears ALWAYS at a low rpm (trying to get to 5th or 6th as quickly as possible without 'bogging'), wouldn't the diminished efficiency of more gears to 'row'/'wind' through be minimal, or almost non existent ? |
#3 | |
It is unusual for it to be higher which would result in lower rpms. If you accelerated the engine to the same rpm in a six, five, and four speed transmission before shifting up you would have slightly less mpg the more speeds you shifted through. More speeds does NOT mean more mpg. The eight speed autos Chrysler and others have come out with are just pulling the wool over the eyes of the unwary consumer. However as you suggest the difference might not be much or even noticeable in practical experience. And a three speed transmission would not be as adaptable to varying road conditions as a six, five, or even four speed. HOWEVER! Manufacturers are guilty of misleading the public in many things. All the time they were increasing the size, weight, and displacement of cars like the Corolla they said "And the mileage is improved!" Not so. My sister in law had something like an 85 Camry that got 38 mpg around town while my wifes 05 Camry gets 22. If you have your heart set on a six speed (soon to be SEVEN speed!) before purchasing get a print out of the final drive ratio of each speed and compare it to the five speed. In many case there IS no five speed to compare it to! BUT you can always SKIP gears as I did on my motorcycles when going cross country or commuting to work. I shifted my ST1100 and 1300 1-3-5.
#4 | |
![]() ![]() ![]() ![]() Drives: 2014 yaris 5 speed Join Date: Aug 2006
now that efficiency is being demaded from all sides, cars are getting bigger and more efficient. the 2014 camry (non hybrid) is close to 1000 lbs heavier, much larger, and far safer than that 85 camry. it is rated at 25/35 and I can get 39-40 in that car all day long. |
| April Yaris Sales: Down | Thirty-Nine | General Yaris / Vitz Discussion | 34 | 05-13-2013 10:34 AM |
| October Yaris Sales | Thirty-Nine | General Yaris / Vitz Discussion | 14 | 11-29-2011 07:44 PM |
| Yaris sales numbers in Puerto Rico... | Yaris_PR | General Yaris / Vitz Discussion | 9 | 06-30-2007 08:59 AM |
