Old 08-08-2014, 02:40 PM   #1
sadarahu
Drives: Yaris 2007 Silver/US model
Checking around the battery and fuses is easy enough to figure out, but can you tell where the other straps connecting to the chassis are ?
My Battery Charge light is ON again , and no horn. While I was driving few days ago the horn came on for a few minutes, the later it disappeared again. It definitely looks like it is is some connection problem and I'm glad I did not replace alternator yet, as it might be a quick fix. The only problem is to find where the connection is bad. Is there any way I can use multimeter to figure that out.
sadarahu is offline   Reply With Quote
Old 08-08-2014, 02:58 PM   #2
Grab the wiring diagrams portion of the service manual from the Micro Image Forum (http://www.microimageonline.com/foru...32-YARIS-FILES).
Look at page 60 of the wiring diagrams for the under hood ground locations. With a multimeter, measure the resistance between the negative battery terminal and each of those points. It should measure very close to zero ohms.
charging issues help please shockedmustang DIY / Maintenance / Service 9 02-24-2014 01:28 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
Good source for the tiny, half-height OEM fuses? schleppy In Car Entertainment + Electronics (audio / video / alarm) 6 05-19-2009 04:55 PM
Replacement Fuses Meteorite_Marty DIY / Maintenance / Service 6 12-30-2008 04:15 AM
