Old 08-09-2014, 01:16 AM   #1
crazylegs
Drives: 2007 Yaris
so my next step should be to physically trace the wires from the peddle to the ECU or is there an easier way of doing that?
thank you again for your input
crazylegs is offline   Reply With Quote
Old 08-09-2014, 06:28 AM   #2
Yes. You would disconnect the pedal connector and the smaller ECM connector
VPA: Red wire on pedal connector
VPA2: Blue wire on pedal connector
On the ECM connector A21 they go to pins 55 and 56 (same colors as other end)
With both ends disconnected, first measure the resistance between the two wires, which should show as an open circuit. Then stick a small piece of wire into the ECM connector to bridge the two wires at that end and measure again. This time the resistance should be very close to zero.
DIY Gauge dj92 Fuel Economy Forum 11 12-06-2013 10:03 PM
Check engine light code: P0724 OttenVT03 DIY / Maintenance / Service 4 10-16-2012 02:12 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
