#55 |
DIBS!
#56 |
Already had you in mind.
#57 |
#58 |
Question for something I also have in mind....does the stock rear badge have a slight curve in it or is it pretty much flat??? I'm hoping its flat as Calista Flockhart.
#59 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
bump...I'm getting my Vitz "bolt" rear emblem and front emblems in soon...and need this for pointers.....
#60 |
Look mum no stars!!
whats their to know about badges...u can even rip it apart from ur hands....
#61 |
what can't keep at least one of the badge threads at the top so people don't come and ask everyday?
#62 |
![]() Drives: 2007 Blazing Blue Yaris Join Date: Feb 2007
Any chance I could get a how to on this process? I would like to take the front and rear off and do the same. Primer? Paint? How to get the badges off?
#63 |
Front emblem can be removed from the black housing (go look at yours to see what i mean), by gently heating and "sawing" away from behind with fishing line.
Same exact procedure for the rear, except there is no housing, it is attached directly to the hatch. You will need to find some 3M body tape to reinstall the emblems. DO NOT use regular double sided tape from the hardware store, its way too thick, wont be as strong, and will look like shit. Body tape is whats used to install spoilers, body kits etc. Its super thin, and SUPER strong, so be careful when you are placing the emblems. That should cover it, now go do it. |
#64 |
Lurker supreme!
Thanks Chris... I'm hoping to do the rear emblem this weekend.
As for painting, do you suggest sanding it a bit first to prep, then using a primer, then paint? I'm assuming spray cans for both primer and paint, with paint specially formulated for plastic. Any top coat? Thanks! Z
2006 Red Blitzed RS 5-door |
#65 |
800grit wet sand > plastic adhesion promotor primer > base coat > clear coat.
Let it settle a few days, then compound pase the emblem, buff clean, then wax. Install. |
#66 |
I drive a yarrrris
Drives: 07 Sedan Polar White Join Date: Sep 2006
deff do the above, or else you'll have to redo them... (dont look at me...)
![]() Docotrs say all the drikning has mesesd up my seplilng and radieng will work for parts |
#67 |
What is "compound pase" the emblem?
#68 |
Remove fine scratches, oxidation, coarse swirl marks and water spots!
Here’s your antidote for the mildly neglected car. 3M’s most versatile rubbing compound is aggressive but safe against fine scratches (grade 1200 or finer), light to medium oxidation, pesky water spots and coarse swirl marks. The super-fine cut abrasive wears down sharp edges and smoothes out the paint’s surface, preparing it for a polish or glaze, followed by a protective wax. |
#69 |
Lurker supreme!
Cool!
#70 |
![]() Drives: 2006 Scion XB Join Date: Jan 2007
I'm a big fan of Black Emblems on white, but normally shave them altogether - that looks damn nice
#71 |
Its actually been changed up a little while ago.. but Ive since removed the NETZ badge, and going back to a color matched toyota emblem.
#72 |
ok am I missing something isn't what is in your pic called the "lightning bolt"? or are the netz and the lightning bolt the same thing?
| Response from Toyota | Driver | New YARIS Purchase Forum | 22 | 09-04-2006 07:44 PM |
| Toyota Delays | Buckethead | General Yaris / Vitz Discussion | 3 | 08-26-2006 03:16 AM |
| Toyota Yaris to Sponsor FOX's "Prison Break" | YarisBueller | General Yaris / Vitz Discussion | 0 | 04-30-2006 08:01 PM |
