Old 08-09-2014, 09:53 PM   #1
Originally Posted by duende_80 View Post
Hello CTScott, I've been all day checking the pins of the two controls with multimeter and now to put the original remote car I have found that does not work the front sprinklers, nothing comes out of water and do not know what could be doing something noise but only the wipers move.
Check the 15A WSH fuse that is in the fuse panel under the dashboard.
Old 08-10-2014, 03:02 PM   #2
duende_80
duende_80's Avatar
Drives: Toyota yaris D4D
Thanks CTScott today look fuses and after remembering all engineers toyota by putting the fuses where they have unsuccessfully to remove the fuse probe front and now operate sprinklers, not because they would not work yesterday, but now I have a dilemma, as the fuses are removed? is that the hand position and was not able to get any.
Regarding connectors with multimeter I managed to discover that pins have continuity in every position, match all pins with the original remote all less intermittent position front and roulette to vary intermittent but only at position + choices and this last if you do not understand.
Sorry for the translation since I do through a translator, (spanish --> english).
duende_80 is offline   Reply With Quote
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
DIY Variable Speed wiper stalk install DanQ DIY / Maintenance / Service 27 08-03-2017 07:22 PM
Florida Yaris Roll Call: Part 3- Post Hacking! Sabretooth Southeast 81 05-22-2009 10:39 AM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
