Old 08-10-2014, 06:40 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by nookandcrannycar View Post
I'm assuming (from a U.S. perspective only, of course) that you mean when what we call the ECHO first came out ? The base pice on the 07 5M USDM 3-door was at least 11k+, IIRC.
I agree.
Good points. The only one of those that matters to me personally is the 6-speed manual (which of course the Yaris has in other markets ).
What percentage or fraction of your ability to do the above is attributable,do you think, to the fact that you've removed your rear seating area, and other items . Even if I could squeeze a couple more MPG out of an automatic over the same car with a manual, I'd still want the manual (as long as the model in question isn't really heavy) knowing I could push the car and compression start it in a pinch if I needed to do that.
Yep +++ .
Actually the base 2007 Yaris was $9999. And the 6 speed Yaris manual in other countries has a much better ratio for gas mileage than our 5th gear does, our 5th gear is totally useless.
As to my gas mileage, very little. My 2nd tank of gas I managed to hit 44 mpg. The car was completely stock, and I still have no idea how I managed it. A better sorted gear box would make it easier.
Originally Posted by Flipper_1938 View Post
I personally don't want stop-start or direct injection. Neither of those technologies are proving to be trouble free.
I really would prefer my existing yaris didn't have ABS (ASB= Anti-Stop Brakes)
A 6 speed manual trans would be nice though.
stop start is simply a better battery/heavy duty starter. Other countries, such as Japan, they are standard and have been for quite a while.
While Direct Injection has had some odd problems, I am sure they will be taken care of, and the benefits are massive. A 2liter turbo Mercedez Benz can get a 26/38 EPA rating, am I really suppose to believe a Yaris cannot match that?
I was going by a general assumption that the set up on a 6-speed vs a 5-speed (on average) would allow the 6-speed to be at a lower rpm (and likely higher MPG) than the 5-speed at the same MPH.
If one wound through the gears ALWAYS at a low rpm (trying to get to 5th or 6th as quickly as possible without 'bogging'), wouldn't the diminished efficiency of more gears to 'row'/'wind' through be minimal, or almost non existent ?
Totally non existent if you do it right, and much better than a "three speed." That is just absurd. If you shift our current 5 speed at 1500 rpm's, you are in 5th before you hit 25 or so. And if we had a 6 speed and better gearing it would help gas mileage.
In most six speed transmissions the highest speed is equal to or lower than the comparable highest speed in a five speed, four speed etc.
It is unusual for it to be higher which would result in lower rpms.
If you accelerated the engine to the same rpm in a six, five, and four speed transmission before shifting up you would have slightly less mpg the more speeds you shifted through. More speeds does NOT mean more mpg. The eight speed autos Chrysler and others have come out with are just pulling the wool over the eyes of the unwary consumer.
However as you suggest the difference might not be much or even noticeable in practical experience.
And a three speed transmission would not be as adaptable to varying road conditions as a six, five, or even four speed.
HOWEVER!
Manufacturers are guilty of misleading the public in many things. All the time they were increasing the size, weight, and displacement of cars like the Corolla they said "And the mileage is improved!"
Not so.
My sister in law had something like an 85 Camry that got 38 mpg around town while my wifes 05 Camry gets 22.
If you have your heart set on a six speed (soon to be SEVEN speed!) before purchasing get a print out of the final drive ratio of each speed and compare it to the five speed. In many case there IS no five speed to compare it to!
BUT you can always SKIP gears as I did on my motorcycles when going cross country or commuting to work. I shifted my ST1100 and 1300 1-3-5.
The Yaris six speed box has a lower 6th speed, which would result in much better gas mileage.
Originally Posted by juicyjosh View Post
Guys and gals, we all realize the 2014 Yaris is a 2005 Yaris, which is a 2007 Daihatsu Charade..., right?
Would YOU buy a 2005 100-hp FWD car... TODAY IN 2014?
I know I wouldn't.
There's also a minimal commission payout to Toyota sales reps for selling the Yaris, so the sales reps aren't going to be pushing these cars to begin with. The point is significant: Salespeople aren't going to spend 4 hours to trying to convince someone to buy a cheaply-made car hoping to make $1xx.00 commission when they can much more easily sell a "nicer" Camry or Corolla and make $3xx.00.
But Toyota's milking the 2005 Yaris (a.k.a. 2007 Daihatsu Charade) for all it's worth. The 2012-on Yaris has an exterior and interior refresh, but it's only a facelift. Like everything else in life, what's inside is more important. In the case of the Yaris, the engine, drivetrain, suspension are all circa 2005. (So the 2012 SE has disks in the rear; There's so little weight back there that there's no significant performance benefit.) However for 2012, Toyota remapped the ecu for "softer" throttle response to get an extra 1 mpg City and Highway for the MT. Thanks Toyota for completing the initially only partially botched castration of what little cojones this car ever had to begin with.
I leased the car because of a unique situation I was in at the time where I needed something cheap with Toyota reliability, and I had no time to be working on cars. And I got a 5-speed fwiw. At least it was cheaper than the auto, and I'm averaging 29 mpg on 87 octane, which isn't bad, though could be better for a 2300-lb. car with a very optimistic 106-hp rating.
Hopefully this helps ppl to not lose any sleep over this car's demise.
Love it, but it is also really an Echo from the turn of the century. And they keep a lot of the good stuff out of the USA.
Colin Chapman disciple
Old 08-11-2014, 05:39 PM   #2
nookandcrannycar
I notice that your join date = before I purchased my Yaris. IIRC, The Yaris was first available in May of 2006 in the U.S. as a 2007 model. Perhaps the $9999 = the initial arrivals, and then by October a price increase had gone into effect. The base price of my base model purchased on October 7th, 2006 was $11,050.00.
April Yaris Sales: Down Thirty-Nine General Yaris / Vitz Discussion 34 05-13-2013 10:34 AM
October Yaris Sales Thirty-Nine General Yaris / Vitz Discussion 14 11-29-2011 07:44 PM
Yaris sales numbers in Puerto Rico... Yaris_PR General Yaris / Vitz Discussion 9 06-30-2007 08:59 AM
