Old 08-14-2014, 09:29 AM   #1
Has the power steering motor assembly been changed? It has the torque sensors built into it for determining what the user is trying to do with the steering wheel.
As a side note, I was very surprised to see that your MK1 Yaris has EPS. Our MK1 over here had hydraulic power steering.
Old 08-18-2014, 07:08 AM   #2
fishlurcher
Drives: Toyota Yaris 2003 1.0 vvti
Power steering motor is the one that was on it when purchased, I purchased from auction and fault was existing, so I have not had it changed, mechanic has told me he has calibrated steering when replacement rack was fitted, as steering seems ok when turning right he is not convinced its the Electric power steering motor in response to side note would have preferred it to have hydraulic PS
fishlurcher is offline   Reply With Quote
Old 08-18-2014, 09:44 AM   #3
Try pulling the EPS fuse in in the under bonnet fuse panel and see if it feels fine (other than without the assist you will get a bit of a workout when turning the wheel at low speed).
Old 08-25-2014, 01:24 PM   #4
fishlurcher
Pulled 50 amp fuse that said EMPS, Must be right one as no PS red PS Light on dash also, sadly still seems the same, not centralising completely when turning left
Old 08-25-2014, 01:49 PM   #5
OK. In that case, your problem is definitely below the steering column. Besides the rack itself, it could be a suspension or tire issue.
Old 08-26-2014, 06:23 AM   #6
fishlurcher
Thanks again, Is the castor/camber adjustable on these or is it fixed ? could it be this ? I am starting to think the garage is a bit suspect, will get tracking checked elsewhere again
Old 08-26-2014, 06:43 AM   #7
The caster and camber have a very small amount of adjustment. Has the shop that adjusted your tracking (what we term alignment) given you a printout that shows the before and after of the adjustments that they made?
Tags
steering issues
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Electric power steering Geoff Peace DIY / Maintenance / Service 4 04-10-2018 05:28 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
Yaris TR 1.3 '08 AC problem Eeman DIY / Maintenance / Service 5 07-03-2014 04:59 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
