Old 08-15-2014, 06:32 AM   #1
Originally Posted by detroiter View Post
Considering the car has 221,000 miles on it...AC isn't an issue too much. I do appreciate your offer and most certainly will keep it in mind! I'm actually shocked that even still, the engine currently doesn't use or burn a drop of oil. I'll have to say that Toyota did one hell of a job when designing and building the Yaris.
I'm curious, will the fan still kick on when it gets too hot? What about when using the defrost setting, will that still work when using heat on the defrost setting? I know that one kicks the fan on when you use it, so I'm wondering if it will still work or not...or will it still blow hot air at that setting and then the fan will just kick on when the thermostat opens up?
BTW, those TRD strut/shocks are great. I recently got around to putting them on. Very comfortable and sporty enough to keep in fun.
The fan will still work and in defogger mode it will actuate the compressor (which of course will not spin). Without the AC, on humid days the defogger will blow, but will not have much effect unless you add some hot air.
Nevermind Need To Delete this Post LEXX DIY / Maintenance / Service 2 10-01-2011 02:40 AM
Is a cat delete midpipe stinky and loud? Shinare Performance Modifications 5 10-30-2010 06:48 PM
rear wiper arm delete Giammarco36 General Yaris / Vitz Discussion 20 05-16-2010 09:03 PM
Rear emblem delete shadowking Cosmetic Modifications (Exterior/Interior) 40 04-19-2010 09:38 AM
Rear Seat Delete, help? JustlikeSuki Cosmetic Modifications (Exterior/Interior) 22 09-18-2009 03:54 AM
