![]() Drives: 2006 toyota yaris t3 Join Date: Aug 2014
yes I have checked all three fuses, and they all three seems to be fine.
OK. Next try bypassing the headlight switch. There are a bunch of different wiring configurations for the European built Yaris, so if you can snap a picture of the connector at the base of the switch I can tell you which wires to jump to bypass the switch (remove the two screws that are visible when you turn the steering wheel and the one down by the tilt lever to remove the lower steering column cover).
| Rear running lights not working 2007 yaris | spectra | DIY / Maintenance / Service | 6 | 12-18-2011 10:20 PM |
| wire size for trailer lights | Connoisseur_of_fine_cars | DIY / Maintenance / Service | 0 | 11-03-2011 08:09 PM |
| Argh! Fog Lights No Longer Working! | MadMax | Cosmetic Modifications (Exterior/Interior) | 15 | 07-24-2011 06:47 PM |
| HELP!! Guage cluster not working | joeljcruz86 | DIY / Maintenance / Service | 6 | 05-14-2010 04:37 PM |
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 12:34 AM |
