Old 08-21-2014, 12:26 AM   #1
ECU (Link/AEM?)
*** AEM FIC or better. If you can afford a standalone, do it.
Connecting rods (Molnar?)
*** I sell better rods than Molnar for less money. Or Crower.
Headbolts (ARP?)
*** ARP head stud kit is now in stock.
Low comp pistons 9.0:1 or 8.0:1 (CP?)
*** 9:1 -- 8 to 1 is way to low.
Smaller fixed compressor pulley (about 20/30% smaller?)
*** Sure, why not for a supercharger.
Larger injectors/Rail/Fuelpump/Swirlpot etc
*** AS NEEDED only. might size up the injectors, and a Walbro 255 or similar. return line is recommended.
What about the head, i presume the valves and springs could use an upgrade
*** ONLY if you are going to rev above the stock limit, otherwise that is a waste of money.
and what about the gearbox? How many HP/torque can a stock gearbox take before blowing up? also what about the rev limit on a stock gearbox?
*** I threw 357whp at mine and it never broke. I had a 7300 rpm rev limit. Your rev limit is determined by where your power curve ends, NOT anything else.
