Old 08-24-2014, 08:22 PM   #1
bronsin
bronsin's Avatar
Huh Im surprised it wasn't $70 so I guess you did OK.
But I wouldn't be changing anything unless it was broke, the OM said it was time to change it, or CT Scott told me to...
Old 08-24-2014, 09:08 PM   #2
nookandcrannycar
Pretty much.
Old 08-25-2014, 06:11 PM   #3
5ABIVT
Drives: sedan
I actually just pulled thepcv out from the wifes car. 268k km.. original pcv. shook it and functions. sprayed it out and put it back in. More than likely will put in a catch can and remove the pcv just for fun to see how much oil it might pull.
5ABIVT is offline   Reply With Quote
Old 08-26-2014, 12:40 PM   #4
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
I have had a look into mine's (55Mm) intake manifold and theres just a notion of a thin oil film inside.
Nothing compared to the Blackwater Horizon filter box of a Golf 4 I've seen some months ago
I drive, therefore I am.
dj92 is offline   Reply With Quote
What did you do to your car today? Justin220 Off-topic / Other Cars / Everything else Discussions 150 06-04-2015 11:47 PM
Replaced my ATF markitect DIY / Maintenance / Service 6 01-02-2014 10:10 PM
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
Did some suspension work today... 07typeS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 06-17-2012 05:56 PM
Checked out honda today for comparison..not impressed!! munchkin Canada 1 05-23-2009 07:06 PM
