Old 08-25-2014, 03:53 PM   #1
When you see one with the emblems removed, it was modified. The Yaris and Toyota emblems can be easily removed with a little heat or by using dental floss to cut the adhesive behind them. The Toyota logo can also be removed, but from what I have heard, some MK1s do not have holes behind the logo and some have two small alignment holes.
The rear wiper as well can be removed, but a ~25mm hole is left behind that has to either be plugged or patched.
Old 08-25-2014, 04:05 PM   #2
nookandcrannycar
JOOC, would these also be the best methods re removing the 'dealer ID stenciling' that some dealers affix to the lower driver side corner of the hatch? .....My 2007 didn't come with this, but the 2014 did.
Old 08-25-2014, 04:08 PM   #3
yaris1010
Drives: yaris
hi there ctscott
I understand that the badges can be removed but what about the boot lid switch how do people open their boots once removed?
yaris1010 is offline   Reply With Quote
Old 08-25-2014, 04:20 PM   #4
Originally Posted by yaris1010 View Post
hi there ctscott
That gets a little more complex. You have to add a solenoid to pull or push the lever that used to be flipped by the hatch handle. That solenoid is then driven by a key fob remote and an output of a keyless entry system.
Old 08-25-2014, 04:26 PM   #5
yaris1010
Drives: yaris
I see, what about the latch that opens the boot from the outside can that be removed?
Old 08-25-2014, 04:37 PM   #6
Yes. That is the purpose of the solenoid - To eliminate the need for the outside latch.
Center Console Lid Pops Up! Rigojr DIY / Maintenance / Service 8 11-19-2021 05:31 PM
Suede Shift Boot and Grant Evolution BLK/CF Knob fnkngrv Cosmetic Modifications (Exterior/Interior) 12 04-04-2011 08:37 PM
Shift boot question. Black_griffin6 Cosmetic Modifications (Exterior/Interior) 14 02-06-2011 10:32 AM
Redline shift boot PHXDEMON Cosmetic Modifications (Exterior/Interior) 27 10-01-2009 12:14 PM
Shift Boot ... revisited bigsky2 Cosmetic Modifications (Exterior/Interior) 35 04-19-2007 07:04 AM
