Old 08-26-2014, 09:41 PM   #1
albee213
Drives: No longer own a Yaris
Sway bars usualy attach to the frame of the car or to non moving parts so that they can make both wheels work together to help keep the car level, I understand how one works but these just attach the bottom of one strut to the other strut and the bar is not attached to anything, I do not see how it can make the car stiffer.
The rear axle is solid in a U shape and adding a bar between them just doesnt make sence to me, I am going to try one and not going to argue wether it imporves handling or not. I am just skeptical.
albee213 is offline   Reply With Quote
Old 08-26-2014, 10:03 PM   #2
The brackets that mount the bottom of the shocks to the rear axle are pretty flimsy in comparison to the axle itself. I believe that what the rear sway bar really does is to stiffen up those mounting points.
Old 08-27-2014, 04:03 PM   #3
albee213
"Ahhhh" said the blind man as he saw his wooden leg.
Thank you for that, finally someone who is making some sense!
I might be picking up some Tien Springs and then try one of these sway bars. I just hope it doesn’t lower the car too much, I drive in Seattle a lot and the roads are some of the worst in the country due to pot holes and other obstacles.
I am also dying to get cruise control for my car but have not put to much time into getting the parts, I wish there was just a kit I could by all-in-one.
Old 08-27-2014, 05:20 PM   #4
I can help you with that. I shot you a PM with the cruise control kit details.
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
