Old 08-30-2014, 11:27 PM   #1
nookandcrannycar
2. Leave just the passenger occupancy ECU, and use my Passenger Occupancy Sensor Bypass module. To avoid disassembling the seat, and to save a bit of space/weight, you can replace the four sensors and their cabling with my module. It is intended to allow the passenger airbag to still be used, when the passenger seat is replaced, but basically it takes the place of the sensors and gives you a switch that tells it to arm or disarm the passenger airbag.
^^^^^This wonderful device you invented is what I was so inarticulately trying to refer to in another thread. Would this module work in either a 1st Gen xB or a 2nd Gen Prius ?
Old 08-31-2014, 07:30 AM   #2
Prius - Yes. XB not yet (the XB uses a very different setup and I haven't had my hands on one yet to develop the solution for it).
Old 08-31-2014, 09:17 AM   #3
nookandcrannycar
Prius - Yes.
When you do, definitely let us know...
...and thank you for this information .
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Complete Racing Seat Install Guide advocate DIY / Maintenance / Service 7 11-25-2009 02:26 AM
Anyone know how the passenger seat detection system works? rage2 DIY / Maintenance / Service 5 05-12-2007 07:22 PM
