Old 09-06-2014, 08:22 AM   #1
bronsin
bronsin's Avatar
We get charged by volume to dispose of items other than recyclables or household trash at our recycling center, and normally a run like this would run somewhere between $25 and $40 depending on which dump dude looked at the truck and estimated the volume. Attachment 54039
$40 TO THROW SOMETHING OUT!!!!
First they cut peoples heads off on TV and now THIS!
(could this be the doing of the terrorists?)
Old 09-06-2014, 08:30 AM   #2
I think you may be right. They even charge to dispose of brush (which they then run through a chipper and sell as mulch).
Old 09-06-2014, 10:06 AM   #3
nookandcrannycar
The one I'll be dealing with in California charges $22.00 per cubic yard (with a minimum charge of $25.00 ) or between $78.00 and $83.75 per ton depending on the nature of the contents. Also set higher amounts for stoves, A/C units, TVs, CRTs, etc (at least they take TVs ). In 2009, it was a flat amount for access (a bit over $20.00)....at least for cars up to a Tundra sized pickup.
Tags
carrier, hitch
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
How to turn ON Yaris Maintenance Required light? JohnnyRockets DIY / Maintenance / Service 11 12-14-2012 10:36 AM
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
Ohio Yarii owners: Turn in Concepts needs a Yaris to measure! schleppy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-17-2009 04:20 PM
