Old 09-13-2014, 09:43 AM   #1
blackace4
Drives: 2007 Yaris
First of all thank you for replying. I have a buddy over and he is a general licensed mechanic. He has used his multimeter and has checked voltage and resistance at all points and is baffled. He is now thinking that perhaps the ignition switch has something to do with supplying power or even computer info to the other components that are not functioning. all harnesses are connected correctly. He has checked the battery which is almost new and located the chassis ground but they are good as well. He is about to give up and have us get the Yaris to an electrical specialist friend of his. He charges $200 for diagnoses and then there may be part(s) involved.
blackace4 is offline   Reply With Quote
Old 09-13-2014, 10:22 AM   #2
Have him check the following on the ignition connector:
1. Voltage on grey wire with ignition off (Should be 12V)
2. Voltage on yellow wire with ignition off (Should be 12V)
3. Voltage on pink wire with the ignition in the ON position (should be 12V)
4. Voltage on white wire with the ignition in the ON position (should be 12V)
5. Voltage on green wire with the ignition in the ON position (should be 12V)
3. Foltage
Steering Wheel question heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 33 03-07-2012 01:27 AM
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 05:53 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
