![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
Check your wiring at and around the O2 sensors where you were working. Make sure you didn't pinch a wire, or scrape some insulation off of a wire that may be intermittently touching bare metal. Shorted wires will cause crazy stuff.
2nd, put a scanner on it to get the code it is throwing. That way you'll at least have a starting point. A lot of today's scanner have troubleshooting info in them that will give you tips as to where to start looking for the problem. If you don't have access to a better scanner with troubleshooter info, go to Autozone, they can at least put a generic OBD2 scanner on it to pull a P code. |
#2 | |
![]() ![]() ![]() Drives: 2011 Yaris RS 5 door 5 spd Join Date: Aug 2012
I`m probably just going to swap it out and hopefully that will be the end of it. I`ll update you guys when I have done so. Thanks for all the input guys!
![]() TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges... |
