Old 09-18-2014, 01:11 PM   #1
The grey wire should have constant +12 Volts on it and the orange wire gets grounded when the hatch is opened.
Does the door open light come on on the cluster when you open it?
Correction - The above is for a 2nd gen Yaris.
For your 2012:
The Blue wire gets power directly from the body ECU and the black wire gets switched to ground either by the hatch switch.
Old 09-18-2014, 02:21 PM   #2
geoded
geoded's Avatar
Drives: Yaris MY2012 - 1ND-TV
For your 2012:
Is correct, I have 2 colors, black and blue. Black is ground, and the blue have zero volts. ECU problem?
geoded is offline   Reply With Quote
Old 09-18-2014, 02:26 PM   #3
Jump the black to a chassis ground point and see if it comes on. The body ECU monitors the black wire and may want to see it grounded (by the switch) before it supplies power to the blue wire.
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
