Old 09-20-2014, 07:22 AM   #1
beaker
Drives: 07 Yaris 3 door
I have an 07 Yaris hatchback, auto trans, non abs.
If I wanted to do this upgrade, what cluster do I need to look for? Anyone have a part # or which model yaris to look for to get a cluster out of? Will a sedan cluster work in my hatchback?
Thanks
beaker is offline   Reply With Quote
Old 09-20-2014, 07:56 AM   #2
Thanks
Sedan cluster is a different shape and has a different connector. You need specifically an 07 or 08 S cluster without ABS. I don't have the part number handy, but there is only one cluster that meets that spec.
For non direct solutions, you can use an 09-11 cluster, but all 09+ have ABS, so the ABS and BRAKE lights would have to be disabled or they would always be on. For 2010-2011 the TRAC light would also have to be disabled.
Old 09-20-2014, 08:36 AM   #3
beaker
Cool, thanks for the answer.
Which of the clusters you have listed above also have the cruise and foglight indicators that I could also utilize when I add these options to my car?
Old 09-24-2014, 08:56 PM   #4
None would work for cruise indicator for your 07 (as the ECM on your 07 would not send the proper message to the cluster to light it). All would have the foglight indicator, as your current cluster does as well.
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
2009 Yaris and wind sailing GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-26-2013 07:52 PM
how do I install a different headunit in 2006 yaris? wouterw In Car Entertainment + Electronics (audio / video / alarm) 10 05-13-2013 07:55 AM
