Old 09-22-2014, 03:10 PM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Originally Posted by jambo101 View Post
Youtube has some interesting bypass ideas, this one is rather ingenious and costs nothing.
http://www.youtube.com/watch?v=x4v8l75kP_w
While i was getting the key made i mentioned this little trick to bypass the dealers high price . he said theres an even easier way, why not just tape your valet key to the underside of the steering column,then you can start the car with any $2 replacement key.
Have Yaris will travel..
Old 09-22-2014, 03:39 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
When i bought the car (new) it came with 3 keys.one with the buttons that did everything,one with no buttons that would manually unlock door and trunk and start the car and one key that would open doors and trunk but wont start the car.
I don't think you have a valet key.
Old 09-22-2014, 04:35 PM   #3
jambo101
jambo101's Avatar
Its the key without all the buttons on it.. I thought it was called a valet key but i could be wrong... It looks the same as the one in the video where he digs out the chip.
heres the 2 keys i got that actually start the car-=
Old 09-23-2014, 04:26 AM   #4
jambo101
jambo101's Avatar
I tried the locksmiths suggestion and it didnt work as there was no place that i could put the factory key that would make a regular $2 key start the car.
Old 09-23-2014, 08:09 AM   #5
It would have to be in very close proximity to the coil that surrounds the ignition switch. As mentioned above, removing the lower steering column and then taping the key to the side of the ignition switch assembly would work best.
Old 09-23-2014, 09:50 AM   #6
bronsin
bronsin's Avatar
Sounds like maybe an aftermarket device to defeat the system?
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Help needed! RE: Spare Smart Key zenyvitz DIY / Maintenance / Service 9 09-28-2014 10:29 AM
