09-23-2014, 06:11 AM | #19 |
Remove the steering wheel column cover?
09-23-2014, 08:09 AM | #20 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
It would have to be in very close proximity to the coil that surrounds the ignition switch. As mentioned above, removing the lower steering column and then taping the key to the side of the ignition switch assembly would work best.
09-23-2014, 09:50 AM | #21 | |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
Sounds like maybe an aftermarket device to defeat the system?
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 06:32 PM |
Help needed! RE: Spare Smart Key | zenyvitz | DIY / Maintenance / Service | 9 | 09-28-2014 10:29 AM |
