Old 09-29-2014, 07:36 AM   #1
Originally Posted by Gogogordy View Post
I will be ordering a TRD rear sway on my '11 LB, and the instructions I downloaded are a bit cryptic. Specifically the speak to backing out the shock bolt on one side but not the other.
What the instructions are eluding to with that point is to loosen that bolt either from the nut side, or the head side. I can't remember which and don't know what difference it makes if you turn the head or the nut.
The first time I pulled that bolt was to install the TRD and I headed the instructions. Every time I've pulled the bolt since then I just go at it without caring which end I'm turning.
Old 09-29-2014, 08:04 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
The impact gun only fits the bolt side anyways. So you would not be able to loosen the bolt side anyways.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Trying to install sway bar Black_griffin6 DIY / Maintenance / Service 16 11-30-2011 03:40 PM
Rally Sway Bar setups Bill@WORKS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 09-23-2009 09:01 PM
sway bar... Toyota dealers must be insane! RedRide General Yaris / Vitz Discussion 10 07-24-2009 03:39 AM
