![]() Drives: 2007 Yaris Join Date: Jul 2014
Water Pump Replacement
I just changed out the water pump on our 2007 Yaris at 190,000 miles. It never leaked a drop but began making a disturbing noise that was very difficult to track down. After referring to many posts on Yarisworld, I felt confident the noise was in the pump even though it felt fine when the belt was removed and the pump was turned by hand. The only additional comments I would make are as follows: I never had to lower the front of the engine by 2"; in fact, I didn't lower it at all. The pump can be removed and the new one installed by carefully turning and twisting it a bit.
I bought a replacement pump and a metal gasket from Auto Zone and everything worked out perfectly. Total time to replace the pump and get the car running again was 2 1/2 hours. |
#2 | |
Good point. I found that unbolting the AC tubing mount, that sits by the pulley, also helps with being able to remove it without lowering or raising the engine.
#3 | |
![]() Drives: '09 Yaris 3dr HB 5sp Join Date: Aug 2009
Did you buy the Duralast water pump (AWP-9187)? How many miles have you driven since replacing the pump with an aftermarket? Any issues or recommendations?
"Never argue with an idiot. They drag you down to their level, then beat you with experience." |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 06:23 AM |
| DIY Requests. | TinyGiant | DIY / Maintenance / Service | 13 | 10-29-2008 10:39 AM |
