Old 10-01-2014, 05:52 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
TRD unit should be helical, any chance the LSD has a part number on it?
Old 10-01-2014, 06:28 PM   #2
I think the TRD ones are indeed helical, but helical ones still use clutch plates for driving the axles. This is how the bad translation on the TRD site described the LSD and if you look at the cutaway image from the TRD site you see the helical gears as well as the clutch plates.
"Because the limited slip capacity is provided using a number of clutch plates, it exhibits a direct, reliable LSD effect."
Old 10-01-2014, 06:51 PM   #3
xnamerxx
0-60 in slow
xnamerxx's Avatar
CT pic only shows hypoid gears, thats a salisbury unit, as you can see the dual clutch packs for drive and decel. If that was a helical unit you would see the helical gears going across the case.
Old 10-01-2014, 07:00 PM   #4
sheekeebut
Minimalist
Drives: 07 silver sedan
Wouldn't the helical gears be spiral shaped? Like so? http://blog.keyeslexus.com/wp-conten.../06/torsen.jpg
sheekeebut is offline   Reply With Quote
Tags
final drive, gear ratio, lsd, swap, wheelspin
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Rattle Inside Steering Wheel CaptainYaris General Yaris / Vitz Discussion 1 04-01-2011 07:52 AM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
