#1 | |
"Because the limited slip capacity is provided using a number of clutch plates, it exhibits a direct, reliable LSD effect."
0-60 in slow
CT pic only shows hypoid gears, thats a salisbury unit, as you can see the dual clutch packs for drive and decel. If that was a helical unit you would see the helical gears going across the case.
#3 | |
Minimalist
Drives: 07 silver sedan Join Date: Jun 2014
| Tags |
| final drive, gear ratio, lsd, swap, wheelspin |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Rattle Inside Steering Wheel | CaptainYaris | General Yaris / Vitz Discussion | 1 | 04-01-2011 07:52 AM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 10:16 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
