#19 |
![]() ![]() Drives: 2007 LB Join Date: Jan 2009
I don't know a permanent fix for this, but I can say I have seen this happen on fords and a jeep I used to own. Dusty roads and some overactive spiders seemed to be my main problem. I just carried a long zip tie and would ream it out a couple of times each summer once my mechanic friend clued me in.
#20 | |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
CTScott you are always quick with the trouble-shooting and diagrams! Someone should give you an MVP (most valuable poster) award! Thanks, R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it." -The Fitful One
#21 | |
Still living with this distgusting smell, cant use the AC half the time. |
#22 | |
Here's where it is (top left side of the passenger footwell): AC hose.jpg Here's what it looks like when you pull it out of the flloor: AC Hose 1.jpg |
#23 |
Thank you!
#24 | |
I just replaced a cabin filter on a xD and noticed that they have a curved plastic cage above the filter, probably to prevent this sort of thing from happening. ![]() #7 ($4.46) But I doubt it'll fit the Yaris
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 07-24-2009 at 06:29 PM. |
#25 |
![]() ![]() Drives: 2010 3dr hatchback auto red Join Date: Jun 2010
curved plastic cage
That cage is in my 2010 3 door HB, but no filter or tray.
#26 | |
#27 |
Drives: 2008 Yaris Join Date: Sep 2012
I just fixed the AC condensation leak for $2
I had the same problem with my 2008 Yaris. The drain was plugged with some mold or algae and water was sloshing and leaking into my passenger floor. The fix is simple. Go to the department or grocery store and get a turkey baster (I paid $2 for one). Lift your carpet back from the top under the passenger side of the floorboard. You will see a rubber hose about a foot long and one end goes into the floor/firewall, gently pull it out. Once removed from floor you can see into engine compartment. Fill a container with about a pint of water and a couple of ounces of bleach and mix. Now take the turkey baster and fill it full with the water mixture and blast it into the end of the rubber hose, holding the baster tight to the hose. Now squeeze it 4 or 5 times like you are unclogging a sink. Now pinch the rubber hose and snap it back into the hole in the floor board and the water should start flowing quickly. I repeated the process to more times and it works like a charm now. It saved me a $50 service charge and I now know what to do if it happens again.
#28 |
2ZR swap. DO IT! Ask how!
Thread necro! I just did the quick drain fix on mine. Got about 2 cups of water out of it, but nothing that looked like a clog. I suppose it wouldn't hurt to get an air filter next time I order parts...
On an unrelated note, I think I just found the entry site for my AFR sensor cable! |
#29 | |
I love the back of my car, the front... not so much |
#30 |
For RHD cars it is the same but on the opposite side of the center console.
#31 |
#32 |
Never mind, found it
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 01:22 PM |
