Old 10-05-2014, 02:34 PM   #1
aspro
Originally Posted by woops View Post
the mount under the battery tray is often overlooked, i've replaced those on about 5 cars in the last two months.
Most people / mechanics do not bother to give it a good look.
regarding your 'rumble' when braking...
I'd check the RIM / wheel temperatures after a normal daily drive
if a front rim/wheel is hotter than the other, it probably means a sticky brake calliper piston or a bad wheel bearing...
same goes for rear wheels but IIRC they have drums at the back, right?
Warped rotors will cause a rumble as well as air in the brake lines. Did you have the brakes bled recently?
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 10-05-2014, 08:10 PM   #2
aspro
I just properly read your post. I take back what I said. If you're not feeling anything in the brake pedal and you replaced your rotors then chances are it isn't your brakes. Maybe stabalizer links? Or bushings in that specific area of the drivetrain?
Old 10-10-2014, 09:11 PM   #3
CB900F2
Drives: 08 Sedan
Thanks aspeo.. Going to check the various bushings next...
CB900F2 is offline   Reply With Quote
